cracked frame.
Old Aug 7, 2000 | 03:18 PM
rbowman's Avatar
hi, I just found a small crack in the frame of my 86 LT250R. I've heard that this is a common problem with these type quads. Now my question, if the frame has a tendency to crack, do I find a reputable welder to "patch" up a relatively thin wall tubing, or try to locate another frame?? I know racers use a frame by Laeger, but I can't seem to locate such a business anywhere. Nor can I find an aftermarket dealer that carries everything but a good, solid frame. Otherwise its a great quad. Starts on 2nd kick, even though it needs a serious rejetting job. Came from 3,000 feet down to where I live now, 6 feet. Any replies would be greatly appreciated. Thanks in advance. BTW, the crack is down under the left peg where that back tube meets the horizontal tube.
Old Aug 7, 2000 | 04:39 PM
Fireblade74's Avatar
That is the same place mine has cracked before also. I did weld it up and it seems to be holding alright for the time being, but time will tell. I welded it only about 1 month ago, and have ridden it maybe twice since then. I would try welding and see how it holds. An aftermarket frame is the best way to go, but I can't justify spending that much on my quad, so I plan on building my own, much stronger frame. I have cracked mine in every place I know possible, so I have an idea of what needs to be reinforced. Later
Old Aug 7, 2000 | 05:12 PM
rbowman's Avatar
I can't find any aftermarket frames at all. I just spent 3 hours searching the internet and mags and came up with ditto. The closest I could figure it is ATV Salvage in KY. And who knows if their frames are any good. Welding it seems more and more probable now.
Old Aug 7, 2000 | 06:07 PM
speedy2's Avatar
RBOWMAN you might be able to find one at www.eastcoastatv.com
Old Aug 7, 2000 | 08:24 PM
rbowman's Avatar
Thanks speedy,
It was exactly what I'm looking for.
Old Sep 26, 2000 | 07:10 PM
juggalo's Avatar
i have an 86 LT250r and i cracked my frame in 2 places. it really sucked. but i went to a welder and he foxed it right up for me. not very expensive either. just make sure the welder knows what hes doing before you let him do it. don't let any old guy with a welder do it. so far i haven't had any problems with the welding so its good i think.
Old Sep 26, 2000 | 08:45 PM
BrinkWeld's Avatar
As a professional welder I may can give you a few tips. First help out the welder (lower cost also) by removing any items that are in the immediate area of the crack so all he has to worry about is the welding. Ask to have it welded by the TIG process as this is a much more accurate way to weld. Also it generates no splatter and is just right for welding thin wall tubing and brackets. This is the same process that is used to weld airplane frames together. Also don't forget to drain any gas in the tank and and clean the weld area of any mud, grease, etc. Good luck!
Old Sep 26, 2000 | 08:52 PM
rbowman's Avatar
Thanks for the replies,
I called a local weld shop this afternoon after work and they quoted me between $35 and $50 to do it. Thats after the footpeg and nerf bar removal, etc... Seems like the best way to go now I think.
Old Oct 1, 2000 | 02:21 PM
rbowman's Avatar
Well, got home from work the other day, my quad was gone. I got a phone call from my brother sayin he "borrowed" it and the crack in the frame broke all the way through now. Think I'm gonna have to kick his @ss now.
Old Oct 1, 2000 | 10:57 PM
lt250rman's Avatar
That blows!
1991 Lt250r :
Ceet seat cover,DG alloy front bumper,DG alloy rear grabar,DG alloy nerf bars ,Emgo bars,Pro design kill switch,Maier plastic(Looks awsome I put lots of cool stickers on it),Uni air filter,Shockwears,Parking brake block off,RTC clutch lever,Motion pro twist throttle(took a while to get used to!),Leager A arms ,Ohlins front shocks(got them with the quad the look kinda old),Homemade motor skid(from speed limit sign),Turf tammers on back,IPT hole shot up front,And probly other stuff to but I cant think of all of them rite now. Please go to www.screaminglt250r.homestead.com
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
