Trimming my front fenders
Old Jun 22, 2004 | 12:01 AM
GTFZ250's Avatar
Default Trimming my front fenders
Do any of you know any websites on this subject or have any tips for me?
Old Jun 22, 2004 | 12:27 AM
ShadyRascal's Avatar
I did the fenders on my kid's Blaster. What I did was map out where I wanted to trim them, taking into consideration the structural strength & stability once it was cut, and used masking tape to pick out a look. Then, I covered the fender with masking tape, drew my cut line with a magic marker, and used a plain ol' saber saw (you know, uppy-downy jig saw) with a medium toothed blade that was shallow front to rear so I could turn a tight radius with it. Don't drink any coffee first! Relax, go slow, and the saw (which mine is variable speed that I kept on slow to mid speed) will eat its way thru very easily. Follow your line with a smooth fluid motion. When it's cut, pull the tape and your cut line will be better than you think. Trim excess with a sharp utility knife or a file, and I then took 100 grit sandpaper on a block and did the edges to make them all nice and even. Your work will look like a pro did it, then you can brag about your skills in the lost black art of plastic work.
Old Jun 22, 2004 | 12:28 AM
It's important to cover all areas with masking tape that the jig saw will touch, so the vibration doesn't scratch up the part that stays attached.
Old Jun 22, 2004 | 03:54 PM
GTFZ250's Avatar
K thanks alot for your help and advice![img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 23, 2004 | 12:03 PM
z250freak's Avatar
Try and get some pics up when you do it. I wanna see what it will look like.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
