Small solution to a winch?
Old Jun 23, 2004 | 05:45 PM
ElectricShift's Avatar
Default Small solution to a winch?
Does anyone know of anything similar to a come-along that I can carry on my Z250 incase I get stuck? I have been using the suzuki alot more now since the grizz is having reliability issues and I have no winch, so I am looking for alternatives....
Old Jun 23, 2004 | 08:36 PM
MBrooks420's Avatar
I have seen a small crank style winch on e bay. It was small, under $50 and was originally an accessory for a Kawasaki I think.
Old Jun 23, 2004 | 09:15 PM
Syrupdawg's Avatar
There are hand cranked winches like on boat trailers
Old Jun 23, 2004 | 09:52 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Black Max Ratchet Winch. Got mine from Rocky Mountain.
Old Jun 23, 2004 | 10:30 PM
UltimateAussie's Avatar
yeah a a second on that black max rachet winch. i saw it in cabelas
Old Jun 24, 2004 | 08:51 AM
hitman1970's Avatar
if you get stuck on a strait axil atv all you need is some good nylon rope. tie one end to the axil and the other to what ever is close and solid then put it in gear and go. the rope winds up on the axil and out you go. a poor mans winch but it works.
Old Jun 24, 2004 | 09:31 AM
Chilly's Avatar
The Black Max looks like it would bend or break the racks if it was under any amount of load, I use a 2 ton come-along. Quite a bit cheaper, and a lot more pull for the money. One thing, you should carry some chain and a grab hook to use with it, rope stretches and the length of the chain is easy to adjust with the grab hook.
Old Jun 24, 2004 | 12:43 PM
Man thanks for telling me about that that sounds like a good trick! I might even give it a try next time im buried in the mud.
Old Jun 24, 2004 | 06:12 PM
MBrooks420's Avatar
Ahhh, the ol' tire winch. It's easiest to have a rope with a loop at both ends. You loop around a tree, or another bike, and place the other loop around the tire tread.
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
Ask the Editor
Sep 14, 2015 08:57 AM
