my tire moved over on the rim?
today i went off this jump a lil crooked and i landed on my rear left wheel.well my buddy noticed the wheel was wobbling and i looked at it and one part of the tire moved like an inch inward from the outside of the wheel.it didnt loose any air or anything.how do i get it back?
Sounds like you almost poped the bead on the tire. Should be able to let all the air out, mix some soap and water to act as a lube and get the tire and wheel good and wet. Fill the tire with air and the tire should pop back out. Be careful to stand well clear of the tire while filling. If you have never done much work with tires take it in to your local shop and they can fix it easily. Hope you didn't do any damage to the rim, should take a close look and make sure it didn't get bent.
DeFox500
Technical and How-To Articles
Jul 26, 2015 02:07 PM
Jul 24, 2015 11:57 AM
