Wheel Center Caps-'03 Ozark
Old Aug 29, 2004 | 01:04 PM
harrydunn's Avatar
Default Wheel Center Caps-'03 Ozark
2003 Ozark--Does anyone have an alternative center cap they use or some sort of trick to keeps these little boogers on? At almost $6.00/piece I'm getting tired of replacing them. I've been losing them at the rate of around 1 per month. Just replaced the front wheel bearings with sealed bearings and am wondering if the center caps are even necessary anymore. Thoughts???
Also, along the same lines, does anyone know where you can pick up the $1.32 fender clips cheaper than what I'm finding online? I lose those things constantly! Would rather not use zip ties, screws, etc... as the clips are designed to give first and save your plastic.
Thanks.
Old Aug 29, 2004 | 01:42 PM
Ozark38's Avatar
I never found a way to keep them on so I just pull the front ones off before I go riding. I too got tired of buying them..............[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Aug 29, 2004 | 05:51 PM
rolsmojave3's Avatar
i don't think you need them they just cover that nut hmmm maybe super glue them to the rim
i don't know about them clips i have lost quite a few on my eiger too
Old Sep 7, 2004 | 04:54 PM
ozarkmaster's Avatar
i put super glue on it has been for one whole week of ridin.
Old Sep 7, 2004 | 05:39 PM
ElectricShift's Avatar
Maybe buy some ITP aluminum center caps I bet they will fit
Old Sep 7, 2004 | 07:14 PM
4xZuk's Avatar
I drilled 1/32 holes in the caps, ran a 12" loop(3 times around) of safety wire around the "x" flange, then threaded the ends through the holes. Next, I twisted the end for 3/4", clipped the excess off w/ side cutters, and folded it over. I have not lost a cap since doing this. I, like you, got tired of buyin' 'em!
Joe454
Nov 20, 2020 01:19 PM
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
cboler9
Sep 24, 2015 08:35 PM
clscott84
Sep 21, 2015 10:16 AM
