03 Z400 chain adjust. problem
Old Aug 29, 2004 | 09:33 PM
Z400rider66's Avatar
Default 03 Z400 chain adjust. problem
I went to adjust my chain today and the upper left bolt of the four that you have to loosen will not move. I sprayed wd-40 on it and still had no luck. I can still adjust my chain with it locked up i just don't feel right about it. Has anyone had this problem or do you think it is going to be a problem? I can still get the bottom two bolts lined up evenly.
Old Aug 30, 2004 | 01:44 AM
13inc's Avatar
The chain adjustment sucks on these bikes.Hard to believe this was the best they could come up with
Old Aug 30, 2004 | 11:04 AM
delow350's Avatar
use a cheater bar.
Old Sep 1, 2004 | 04:45 PM
Z400ED's Avatar
BINGO.. i had to use my foot to break the bolts loose.
Old Sep 1, 2004 | 06:18 PM
Tried the foot and this thing will not move, I about kill myself just getting it to go about a cm so I don't feel like taking it all the way off, i'll just leave it.
Old Sep 1, 2004 | 09:21 PM
FsT4WrD's Avatar
Upper left ? Cheater bar works, 1/2 drive works better until you snap it like I did. The 03' swinger set up is by far the worst. Plus it calls for 70 ft lbs of torq.
Old Sep 1, 2004 | 10:20 PM
Beastly1's Avatar
is this a problem on all 03 z400's?
Old Sep 1, 2004 | 11:19 PM
Mars's Avatar
Yes, and the o4 has less bolts but they are just as tight. Steel bolt + aluminum carier = @%!&*!!.
Impact wrench or heat work best. If you heat, heat the bolt head only.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Jul 15, 2015 02:07 AM
