LT230E clutch conversion to manual
Old Sep 15, 2004 | 10:36 PM
MBrooks420's Avatar
Default LT230E clutch conversion to manual
The motor is a total basket case I bought with a parts bike. It lost the main bearings and one logded in, and ruined the 3rd gear in the transmission. I'm pretty sure I have all of the parts for it. If you did this, it'd be likely that you could swap over to a kickstart as a backup, and delete the pull start. This would narrow the motor up a bit. The manual clutch also takes up less space. This means you have the option of running the Quadsport fold up pegs.
Old Sep 15, 2004 | 10:40 PM
jrupp82's Avatar
yeah, that would be a bonus too, i wouldn't mind the kickstart instead of the pull start, we'll see what happens try to get all the info for me, and we'll go from there
Old Sep 21, 2004 | 11:00 PM
MBrooks420's Avatar
If you look in my photos you will see that the motors are very different. I am doubtful, although I didn't take any measurements. A bolt in swap doesn't look likely. It is still possible to make the centrifugal clutch disengauge like a manual.
Old Sep 22, 2004 | 06:21 AM
jrupp82's Avatar
ok, so things are a bit more complicated than i suspected. thanks anyhow, i guess i'm gonna have to try to just get fibers and see if that helps my problem with the slipping. otherwise i'm lost. thanks again
Old Jul 12, 2010 | 06:10 PM
  #15
Jeff Thomas's Avatar
Default Owners Manual for 1989 Lt230E
Can anyone help me I am looking for a copy of the owners manual for a 1989 Lt230E.
Old Jul 12, 2010 | 10:50 PM
  #16
Default Forward gears on a Lt 230E
I can not shift out of neutral, but I can shift into reverse. Is this do to a dead battery, therefore not engaging the automatic clutch? I have a Lt 230E
STLyamwar
Jul 25, 2020 04:44 AM
merryman
Jan 19, 2016 04:29 AM
Proud Father
Aug 19, 2015 10:08 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
