My zilla wont start
Old 09-23-2004 | 08:34 PM
ZillaRider87's Avatar
Default My zilla wont start
it was acting weird for awhile. i shut it off and then kick it back on. after about 7 seconds it dies out, so i do it again, same thing happens. then i try to give it gas to keep it from dieing, and when i do, it goes really high and then bogs down and stalls out even with the throttle half way, what could be wrong?
Old 09-23-2004 | 11:16 PM
needaR's Avatar
dont know.but sounds like it blew a base gasket or something.sounds lean.jetting?
Old 09-23-2004 | 11:50 PM
butters's Avatar
it not a gasket......it it was suckin in air, it would be revvin up high by itself......
Old 09-24-2004 | 12:56 AM
donzilla's Avatar
could be the stator also . check the reeds 2 .
Old 09-24-2004 | 09:37 AM
ZigZilla's Avatar
Check the reeds like Don said.... I bet they are broke
Old 09-25-2004 | 12:23 AM
k thanks
Old 09-25-2004 | 03:38 AM
budrud's Avatar
Mine was doing the same thing and believe it or not it was the circlip on the needle valve. Pull the top off tha carb and make sure the needle is attached to the slider. I know it sounds weird but mine would start and run for a short time and die imediatly if you gave it much throttle.
Old 09-25-2004 | 03:38 PM
wannaracelt500's Avatar
check to see if ur reeds are loose or any thing next to ur carb,reeds
Old 09-25-2004 | 05:18 PM
i got it fixed, all it was was the plug. i pulled it out , looked fine, but i replaced it and it started, i guess somthin was wrong with it?
Old 09-25-2004 | 05:59 PM
needaR's Avatar
it was probably gapped wrong or something
MikeyBoyesq
11-27-2020 03:44 PM
Mphillips
07-29-2015 09:53 PM
Mphillips
06-26-2015 04:52 PM
kodiak450.
06-17-2015 03:22 PM
1000gade
05-27-2015 01:37 PM
Quick Reply: My zilla wont start
