Vinson Gear lubes. What do you use?
I need some input on what gear lubes you guys and gals run in your front and rear diffs of the Vinson
What is recommended ? 80w 90 gear lube? Gl-2,GL-5 or GL-4? Which one?
Thanks in advance.
Zig
Thanks in advance.
Zig
Out of the book: When changing the gear oil, use SAE 90 hypoid gear oil which is rated GL-5 If you operate where ambient temps are normally below 32 F, use SAE 80 hypoid
here are the capacities Front 10.1 US oz
Rear 11.8 US oz.
Hope this helps you out, have a good one!
Rear 11.8 US oz.
