New Z-400 HELP!!!
Old Oct 12, 2004 | 06:24 AM
MURDR's Avatar
Default New Z-400 HELP!!!
The rear left bolt on my swing arm that holds that axle in place. (There Are two bolts on one side and two smaller bolts on the right, by the disc brake. So the four bolts that hold the swing arm in place) The Back left bolt does not want to loosen or tighten. Seems like its stuck or about to brake off. It came loose but then got stuck at mid point and does not want to loosen or tighten. I dont want to snap the bolt in inside my swing arm. What should i do???
Old Oct 12, 2004 | 10:04 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If it's new, is it still on warranty? Make it the dealers problem.
Old Oct 12, 2004 | 11:20 PM
mucky's Avatar
I had the same problem I sprayed a lot of wd40 on it and kept working it back and forth
thats why I changed my swingarm to a roll carrier swingarm
Old Oct 13, 2004 | 12:45 PM
terd's Avatar
the larger bolts are torqued to 73 lbs,and the smaller are 53lbs.i doubt that you can budge them with a 3/8 ratchet.you need to use a 1/2 inch drive for leverage.don't use a socket extention because you may get an incorrect tourqe reading and you MUST MUST retourqe the bolts.
Old Oct 13, 2004 | 05:00 PM
ZButcheR's Avatar
If you look close @ both of them bolts, you will see that the bigger of the 2 have washers on them the smaller 2 do not.
I had the same problem.mine stuck to the indicater bracket......It even bent.....
I ended up striping the head of the blot.....The bracket on the bottom of the swing arm. Has 2 nuts wleded to it.
I took out the bigger of the 2 bolts & just ground the head off the 1 I striped & punched it through.
When I put it back together I got some new washers/Blots &,antiseize,antiseize,antiseize lol.
Nordy
Mar 11, 2003 11:02 PM
smelly
Jan 20, 2003 02:36 PM
rraptorr13
Aug 4, 2002 09:19 PM
thrshr
May 2, 2002 07:37 PM
Toaster
Feb 15, 2002 12:52 AM
