antifreeze leak
Old Nov 13, 2004 | 05:53 PM
ZillaRider87's Avatar
Default antifreeze leak
under the part of the engine where the radiator hose goes into the engine, is there a screw on the bottom of it, cuz mine has a hole that looks like a screw should fit in and im leakin antifreeze out of it
Old Nov 13, 2004 | 06:57 PM
minnrider's Avatar
yes there is a drain plug there........a little further in is a weep hole,if that is leaking then you have a bad impeller shaft seal.
Old Nov 13, 2004 | 07:43 PM
1987LT250's Avatar
thats a weap hole. and what minnrider said its impeller seal. the bolt holding impeller it left handed thread.
Old Nov 13, 2004 | 08:06 PM
ZukZilla550's Avatar
If your ever at a race and it start's to leak you can (for a quick fix)plug it with a piece of a stick.The wood will swell after it get's wet a seal it tight and it won't hurt the engine.I did that at Silver Lake one year so I could finish the race and it worked great.
Old Nov 13, 2004 | 08:38 PM
so how would i go about fixing it, what do i have to order?
Old Nov 13, 2004 | 08:40 PM
Water pump impeller seal for a Zilla is what you need to order.
Old Nov 13, 2004 | 08:42 PM
1987LT250's Avatar
i went to dealer i think it was 13 bux for impeller and outside seal and spring. pull pump cover off and replace the old with new . rem left handed threads on impeller.
Old Nov 13, 2004 | 11:18 PM
alright thanks guys
Old Nov 14, 2004 | 01:30 PM
today i went out to look at it again, and now, its not leaking..., im probly going to replace the seal anyway. but why would it all of a sudden stop?
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
