Hi! (From new Zuki owner.)
Hi all!!
Update on the Drain for the King Quad belt case...
It does have one... it is a rubber plug hidden by the Right hand running board and you can't access it with out nearly removing the entire skip plate... We drain it and a gallon of swamp water came out..... So we are going to drill a minor hole in the skid plate to allow access in the woods.
I'll let you know shortly if the belt is ok...
Later,
Hibrass
Hi all!!
Later,
Hibrass
Just got back from the Suz. dealer and..........damn...............
I KNEW THERE WAS A DRAIN! Luckily, the Vinson's is easier to get at. That should eliminate your "slip" problem. Now remember-the KQ is not a submarine.....repeat.....the KQ is not...J/K! Good idea on the hole. Hey, check out the Dec. issue of ATVRider. There's a feature on the KQ. Also check pg. 64 and read the article. Let me know what you think....................[img]i/expressions/face-icon-small-wink.gif[/img]
4X
Even more good news...
Belt is fine!
Oh and "My KQ is not a Submarine..." LOL
But at least I know that it can take some really deep water. I'll look for a copy of ATVrider and let you know what I think.
Later,
Hibrass
Belt is fine!
Later,
Hibrass
Cantbuytime
Aug 17, 2015 06:33 PM
