Help with Vinson problem
Old Nov 28, 2004 | 03:04 PM
606zpx's Avatar
Default Help with Vinson problem
My wifes 2003 Auto Vinson has developed a new problem. At low speeds, runs great, no problems. It wont get past 38mph for some reason. Seems to sputter some at that speed. Not certain if it is hitting rev limiter or there is some other problem. Air cleaner/plug/belt inspected and OK.
Any suggestions?
Old Nov 28, 2004 | 03:54 PM
hondabuster's Avatar
How old is the gas?
Could also be a plugged main jet. Drop the float bowl and inspect for crud...if you find some, the jets need to be cleaned out.
Old Nov 28, 2004 | 06:36 PM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Pull the fuel line from the carb, turn petcock to prime and make sure you have good fuel flow. There is a screen in the carb inlet fitting. Use a peice of wire to clean it but don't poke the wire thru it.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
