2003 LT Z250 gearchange
Originally posted by: nicks3
I know it is possible to adjsut the height of the stock foot shifter. can anyone explain how you do this?
There is a little bolt where the sifter meets the splines. Loosen that bolt, pull the shifter towards you until it comes off. Then move it where ever you think you would like it to be placed, and re-tighten the bolt.
Thanks LT80, that sounds more like it, rather thna having to remove the shift elver from the transmission. There are 2 sort of tie rod joints above the shifter and that is how I assumed it was adjusted.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
