Can anyone help me on a 86 LT 230s
Old Dec 7, 2004 | 10:54 AM
deonion's Avatar
Default Can anyone help me on a 86 LT 230s
My 230 smokes it is not burning oil and I adjusted the carb it did not help. The 230 is stock. If i have to ring it to get it to stop ware can I get a new stock sleeve just in case.
Old Dec 7, 2004 | 03:53 PM
pendejo's Avatar
If it smokes, it's probably burning oil. I would just bore the cylinder .010 over and get a new piston and rings.
Old Dec 8, 2004 | 12:07 AM
ClarkBar's Avatar
If you got compression, it might not be rings. you can check compression with a gauge, book says it should be 171 to 228 psi. I had that problem with mine, and it wasn't rings. I knew it wasn't because it had to much compression when kicking it over. It ended up being valve seals. They get old and wear out.
Old Dec 8, 2004 | 01:17 AM
pendejo's Avatar
Oh yea, before you tear into it, there's a way to tell if it's rings or valve seals when you do the compression test by the way the compression builds on the gauge. I can't remember exactly how, I'll look it up for ya in a minute.
Old Dec 8, 2004 | 05:35 PM
MBrooks420's Avatar
Most likely it's the valve seals. Very common problem with the 230 motor.
Valder
Nov 28, 2020 07:38 AM
Nekolai1
Aug 25, 2015 10:04 PM
DFWSRT8
Aug 20, 2015 09:24 AM
mr.bear
Aug 5, 2015 07:51 AM
NatePerz
Jul 27, 2015 03:27 AM
