Jeting Qusetions??
Old Dec 21, 2004 | 11:10 AM
bombdsbaja's Avatar
Default Jeting Qusetions??
Hey Guy's,
My stepdad bought a Z-400, he put a yoshi slip-on on it, I'm going to put a UNI air filter on it and re-jet it, most of the riding will be done at Dumont, so my qustion is what size of jet, what type of jet do they use, where should the needle and air screw be set. I have the DS down pretty good just have not been into the Z yet and want to get it close the first time. Any help would be appreciated.
Thanks,
Tom
Old Dec 21, 2004 | 11:28 AM
LTZ's Avatar
LTZ
I ride the same places as you, Dumont and Teagle Wash(Trona). I had my Z on the dyno and ended up with a 155 main, 25 pilot, needle on the 3rd clip, but I can't remember what the mixture screw is at. That's with the lid off, Uni filter w/Outerware, and a MBRP slip-on.......
edit: Thats with DJ main and needle.
Old Dec 21, 2004 | 06:48 PM
YZLTZrider's Avatar
that seems a little lean. If thats what makes it run right then our pipes must be quite a bit different. I run a 170 mikuni
Old Dec 21, 2004 | 07:12 PM
LTZ's Avatar
LTZ
We ran the air fuel on the dyno with a 160 DJ, stock pilot and I was lean off the bottom/mid, and fat up top. Guy says to drop one on the main and go up one on the pilot. We'll see when I run it again? Also, Mikuni jets are alot different than Dynajets.......
Old Dec 21, 2004 | 07:36 PM
mucky's Avatar
I run a 170 jet and sometimes larger depending on where I ride
Old Dec 21, 2004 | 07:41 PM
YZLTZrider's Avatar
that sound more like it
Old Dec 21, 2004 | 07:48 PM
LTZ's Avatar
LTZ
What type of jets are you runnin' Mucky?
More times than not people are runnin' a bigger main than neccesary(not refering to you in particular Mucky[img]i/expressions/face-icon-small-happy.gif[/img]) Unless the dyno is way off I'm gonna try to trust it and the guy who was runnin' it....
Old Dec 21, 2004 | 08:11 PM
mucky's Avatar
its a 170 main, sometimes a 172, the clip is on the second groove and as for the rest im not sure. ive only been into the carb once to change the main
and its an FCR 41mil carb. I had somebody esle tune the motor for me. I have no patience for it
Irunwire
Dec 17, 2006 12:42 AM
430exrider
Mar 7, 2006 12:32 PM
Tyler111
Mar 10, 2004 10:09 PM
bwyj
Aug 24, 2003 07:31 AM
