How fast can the Vinson go in reverse?
Vinson581, How did you get your auto to do 71 MPH? I may be new to this forum but I have been with other forums for years and I have never heard any one say that they could go that fast with any Vinson. A stock auto will only do between 58-60 MPH and a stock manual will only do 62-64 MPH. I have a Supertrapp IDSX, K&N filter and a dyno jet kit that is properly tuned and I did not gain any extra speed with my mods and every one else I have talked to has only got a power increase and did not get a speed increase either with the extra mods so please let us know exactly how you did it.
OffRder15 to answer your main question there is no speed limiter on the manuals that I have notriced other then what the max speed of the gear ratio can put out when the rpm are maxed out.
the vinson has a mod to do the reverse rev limiter by pass, if you search it will come up, its easy to do
a stock vinson 02- will do 62-64 GPS, certifyed, being the display on ALL vinsons will ony read up to 62mph, or 99kmh. due to a goverment regulation i belive
well bigger tires give you a higher top speed, the pipe and cam give you much more bottom end power to turn those bigger tires, for example with only the tires i could get to about 63, just because the thing couldnt rev past there it had no power, add the cam and pipe and wow did it wake it up! i had it on the gps when i did it, and wouldnt want to do it again because thats just to fast on that thing.
v581
v581
