92 lt250r problems
Old Jan 23, 2005 | 11:06 PM
soup's Avatar
Default 92 lt250r problems
The vent tubes connected to the carb are leaking a lot of gas and it is hard to start. It runs well, but it just doesn't want to start sometimes. Is my carb bad?
Old Jan 23, 2005 | 11:17 PM
1987LT250's Avatar
if the overflow tubes are leaking then the float must be stuck open. if you pull the carb and pull the bottom bowl off it ,there will be a float the little needle like thing it pushes up to shut off fuel flow gets gummed up not allowing it to close. ther for your bowl stays over full all the time and leaks out overflow.
Old Jan 23, 2005 | 11:25 PM
NichelsonRacing87's Avatar
the same thing is going on with my LT250R, i checked the float and it wasn't stuck, so i think my carb is garbage, pretty soon i'm going to go with a Keihin 38mm or a 40, since i've dealt with Mikunis all i had were problems, i have a Keihin on my TRX250R and it performs awesome, but still got the old junk 34mm Mikuni on the Quadracer
Old Jan 23, 2005 | 11:26 PM
soup's Avatar
I just got the quad and i didn't intend on spending a lot of extra money on it, so would the carb work better if i rebuilt it or is it better to just buy a new carb (possibly one that is set for alcohol?).
Old Jan 23, 2005 | 11:44 PM
1987LT250's Avatar
hey nicholson when u push float up can you blow into the fuel inlet? you shouldnt be able too. also theres a setting for that little prong u bend it to the setting in manual. that adjusts how far the float has to rise before shutting.
Old Jan 23, 2005 | 11:54 PM
no i can't blow through it, but i never checked on the prong thing, it could possibly be the problem
thanks man
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
