Cams only on Z400...tell me how they worked.
Old Jan 24, 2005 | 06:05 PM
scottd's Avatar
Default Cams only on Z400...tell me how they worked.
Anyone that installed mid range cams ONLY on thier Z400, tell me if you liked the results, and what differences it made. I need to adjust the valves on mine, and was considering swapping out the stockers for a pair of HotCams at the same time. Don't want to pull the top end apart to change gaskets, pistons, of valve springs at this time. (I kind of want the same or better performance that the new upgraded '05 Z400 has) Let me know. Thanks.
Old Jan 25, 2005 | 12:14 AM
2112's Avatar
Cams alone will not give any more power you have to put a piston in it. I put both cams in and there was no differance but when i put the piston in,it runs great. I run a 13:5.1 with 110 octane. I live in louisiana and would be happy to install your cams and i have a shem kit with every shem. let me know yyzgup@netzero.com good luck.
Old Jan 25, 2005 | 12:26 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
I have heard different, I have a bud who rides one, he installed a Yoshi pipe/K&N/ Jets, he said it was good but wanted more, so he went ahead and hot hot cams, and since the Z is double cam, it is said to give you some HP, don't really know if it's true but seems fine to me.
Old Jan 25, 2005 | 06:56 PM
Sandgod's Avatar
You will gain on the top end. It revs much quicker also.. You will lose some low end..
Old Jan 27, 2005 | 12:03 AM
2112's Avatar
Cams will not give you any more hp's it just puts in different areas, but its dose rev faster.
Old Jan 27, 2005 | 12:35 PM
13inc's Avatar
You'll definitely find the rev limiter sooner.I would look into a rev box to go along with the cams.My Z definitely pulls harderwith them.I'm not going to get into a debate over horsepower so I'll leave it at that.
Old Jan 27, 2005 | 10:41 PM
2112's Avatar
We put thing on our bikes to go faster and with just cams you wont I know i tryed it all ready you need a piston!
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
