LT250R Suzuki Problem HELP!!!!
Old Jan 29, 2005 | 02:50 PM
SuZuKi250RaCeR87's Avatar
Default LT250R Suzuki Problem HELP!!!!
Hey everyone, i've got a '87 Lt250r and i can't split the case. I have removed both side cases of the engine and have removed all components like the clutch and so on. I need to take off the bolt going through the bottom end of the engine. One side is coming out of the magneto, and the other is going through a gear that is part of the clutch. Please, I need any info you can give me on how to take this bolt out, and especially which way to turn it and which end is the nut and which is the bolt. Thanks
Old Jan 29, 2005 | 08:45 PM
1987LT250's Avatar
are you talkin about the nut in middle of maneto like the magnetos still on? if so thats lefty loosy and after u take it off u need a puller to pull mag. if thats not the nut ur talking about please clue me in on where this so called bolt is and ill help ya. good luck
Old Jan 30, 2005 | 10:56 AM
sam250's Avatar
Crankcase diagram.
Old Mar 28, 2005 | 04:21 PM
revhardlt250r's Avatar
i jus split mine... MAKE SURE U TAKE EVERY BOLT&SCREW OUT BE4 U TRY 2 SPLIT THE MOTOR OR U WILL BRAKE SOMETHING...!MY FRIEND DID ON HIS.....lol
Old Mar 28, 2005 | 04:52 PM
86LT250RFatty's Avatar
its really hard, get a chissle and a rubber mallet, just tap around the case, you have to break the gasket.
jaime511
Jul 19, 2015 01:58 PM
Jul 15, 2015 02:07 AM
clsharky
Jul 13, 2015 02:07 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
