88' lt250 timing marks
Old Feb 4, 2005 | 11:14 PM
PainBsC's Avatar
Default 88' lt250 timing marks
hi,
i recently asked for help for a wire diagram on my quad, well after i found that the wires where right and i was kicking it over it locked up, now i know why it didnt have spark the stater plate came loose and wiped out the stater assmbly and the rotor assembly, well i purchased a new rotor and stater assembly and a manual parts are here , but the manual wont be hare till next week, can anyone tell me where the timing marks are and where to put them for stock alingment, i can adjust as needed from there, thanks to all that can help.
Old Feb 4, 2005 | 11:18 PM
superevil's Avatar
Should be a mark on the stator plate and a mark on the engine,you just line them up,the mark on the engine is right by where the stator plate goes,its just a little mark,like a little spline thing
Old Feb 4, 2005 | 11:31 PM
PainBsC's Avatar
thanks superevil your a good man , thanks for keeping a bro ridin.
Old Feb 5, 2005 | 02:41 AM
superevil's Avatar
ok i might not have described it well enough.On one of the holes that you bolt the stator to the engine case with there is a little slice right beside the bolt hole,almost like someone took a razor blad and put a slice in it.And,on the part of the case where that bolt hole with the slice goes,there wil be a little spline sticking out,you just match them up
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
