how do you do this>? counterbalancer!!!!!!
Old Feb 28, 2005 | 06:58 AM
superevil's Avatar
Default why hasnt anyone asked this counterbalancer question?
OK on 87-92 lt250r's. you have to line up the gear on the crank with the counterbalancer gear,and there is a punch mark on each gear so you can line them up,but is there also a mark on the main gear and crank to make sure you have the crank and the main gear lined up correctly? What good would having the two gears(counterbalancer and main gear) lined up do if the main gear was wrong on the crank? With all the vibration questions i found by searching i figured this would have come up.i can ride until i figure this one out i dont want a cracked frame!!!,or numb feet and hands!!
Old Feb 28, 2005 | 07:49 AM
superevil's Avatar
im willing to bet about 700 people on here know the answer to this
Old Feb 28, 2005 | 10:28 AM
Duneaddict's Avatar
I do
Old Feb 28, 2005 | 04:04 PM
superevil's Avatar
cmon someone i need to ride! help me out, I dont know!!! i am actually asking the question cause i dont know! I can match up the counterbalancer gear and the main gear but i have no idea how to time the crank and main gear right so it will balance correctly!
Old Feb 28, 2005 | 04:31 PM
86LT250RFatty's Avatar
Default how do you do this>? counterbalancer!!!!!!
Originally posted by: Duneaddict
I do
lol, tell em duneaddict! i only know 85-86!!
Old Feb 28, 2005 | 04:49 PM
1987LT250's Avatar
ummmm hey addict as long as the 2 marks on other gears are aligned its done deal keyways take care of rest.... right? on 87 and newer that is. i thought 86 were only different as they have locating pin for water pump and that special washer on the balnacer drive gear. hmmmm
Old Mar 1, 2005 | 12:39 AM
Duneaddict's Avatar
Sorry to be so sarcastic before... I guess I didn't realize you were asking for help.
There are 3 (THREE) stamped dots to align, not just two... The keyed shaft is only for the removable end of the counterbalancer.
The crank has one dot, the two other gears each have one... aligning these allows perfect timing of the crank to the counterbalancer...
Where most people goof is the last dot on the crank itself... its easily overlooked.
Hope this helps you out...
regards,
Old Mar 1, 2005 | 12:55 AM
1987LT250's Avatar
i guess my book doesnt even show it lmao
Old Mar 1, 2005 | 02:54 AM
superevil's Avatar
my clymer manual makes absolutely no mention of the third punch mark on the crank itself,but it is there. you have to have the main drive gear off,and just the counterbalancer drive and counterbalancer driven gear on,and you can see the mark on the crank. Absolutely no need to apologize,i dont think i was clear enough in my title
Old Mar 1, 2005 | 10:11 AM
Duneaddict's Avatar
I'd highly suggest the factory service manual.... clymer is less than good for these particular models... just my $.02
