Vinson Brakes
Old Mar 9, 2005 | 10:29 AM
jknudson's Avatar
Default Vinson Brakes
I just replaced the brakes less then a year ago on my 02 vinson and I need to do the rear brakes again. I had the dealer do them the last time however I would like to try it myself this time, I was looking at it the other night however I couldn't figure out how to get pads off, can anybody share their knowledge with me on how to perform this task?
Old Mar 9, 2005 | 01:13 PM
dbuz's Avatar
From what I remember, there are 2 allen head bolts holding the caliper on. I've replaced my rears and fronts once. It is probably about time to replace the rears again. Use a large screwdriver to pry the caliper in all the way so the new brake pads will go on. When your brake fluid gets low, that is a good indication that the pads are getting low too.
Old Mar 9, 2005 | 01:39 PM
jknudson's Avatar
So I just loosen those allen head bolts and the pads come loose from there?Thanks!
Old Mar 10, 2005 | 02:07 PM
dbuz's Avatar
First put a large screwdriver between the pad and rotor and pry the pad all the way against the caliper. Then take the allen head screws out.
Old Mar 10, 2005 | 02:12 PM
jknudson's Avatar
Ok Thanks!
Old Mar 10, 2005 | 09:03 PM
Stainless's Avatar
Be carefull with using a screwdriver. I tore the seal on a caliper once doing that. In my opinion using a c-clamp or some sort of pliars is safer but if your carefull a screwdriver will work. I also take the break fluid resevoir cap loose to allow the fluid to raise without building pressure.
Old Mar 10, 2005 | 11:15 PM
Vinson581's Avatar
dont take the cap off, all it can do is cause air to get back in the lines, its a sealed system, keep it that way. i do this on every bike and car, and it always goes smooth as silk.
v581
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
