LT250R CRANK!!
unless your present crank is damaged or not working properly,or the main seals are bad,you probably wont noticed a big diference in putting in a wiseco crank,as a matter of fact,some people prefer the stockers to wiseco. most people would think the crank makes a huge diference because most of the time the top end is redone when the crank is replac---as it is kinda a good idea to rebuild the top or at least re ring it while its all off. i went from stock crank to wiseco hot rod to stock again and cant really tell a diference. but the wiseco can be bought for about 160 from ebay brand new.and the stocker is rediculousy exspensive ,like 3-400 bucks for a new one. unless your buying a performance racing crank or something i wouldnt expect a huge diference
