Z400 ENGINE PROBLEM??? Wont run
Old Apr 16, 2005 | 05:33 PM
04suzukiz400's Avatar
Default Z400 ENGINE PROBLEM??? Wont run
i talked to my dealer he said to use a 140 jet, i put it in, i rode it for a little bit, now i come back and it wont idle. i let it cool down, warmed it up again as soon as it gets warm it wont idle and quits. after a lil bit it will start again wont idle for s|-|!t, touch gas cuts and kills. what is goign on now!!
Old Apr 16, 2005 | 07:12 PM
GLDIVER's Avatar
Bummer... But you have to realize, jetting an engine is not just a simple screw out one jet, screw in another thing. Any time you change the main jet you will likely have to adjust the mixture screw some. And the idle may need to be adjusted as well. It's going to take some tweeking and testing to get everything adjusted to the new jet.
Start with a clean air filter, fresh gas and a new spark plug. It will take some time and effort to get to the right combination of jet and settings for your particular set-up.
Good luck! And most important have fun!!
Old Apr 16, 2005 | 08:59 PM
i just put everything back to stock, and it wont run. runs for a little then quits and wont start/ idle! what did i do?
Old Apr 16, 2005 | 10:03 PM
hondabuster's Avatar
Is it back to being totally stock...air box lid and all? Wheres the mixture screw set at? All lines and cabels connected back up? Choke cable binding?
Old Apr 16, 2005 | 10:04 PM
rolsmojave3's Avatar
check and see if it's getting gas at all...you also might wanna check to make sure something ain't blocking the airfilter..hope that helps
Old Apr 17, 2005 | 12:03 AM
i know its getting gas. it will run until it gets warm then wont. somebody please help i have group ride tomorrow and i really want to go. any trobuleshooting tips?
Old Apr 17, 2005 | 12:52 AM
original stock settings cept air filter and slip on
Old Apr 17, 2005 | 01:18 AM
everything is hooked up, i am supposed to go on a ride tomorrow any tips!?
Old Apr 17, 2005 | 06:08 PM
HughJazz's Avatar
Try a new spark plug
Old Apr 17, 2005 | 06:22 PM
new plug did it, popped first time ran great
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
Zee400
May 31, 2015 12:48 PM
