what will hang with a Quadzilla
Old May 11, 2005 | 07:40 PM
GOHARD's Avatar
Default what will hang with a Quadzilla
Just wondering what stock quads will best hang with and zilla.Is there anthing that can actully run side by side with one.
and how do the 250 r s and lt s hang iwth them
thanks
Old May 11, 2005 | 09:23 PM
flynhi250r's Avatar
Banshee is the only thing close stock. But finding a stock banshee and even more finding a Quadzilla stock is hard to do. I'm pretty sure stock YFZ's and 450r's would have a hard time keeping one in sight.
BESTz400ryder's Avatar
Stock absolutly nothing will run with the Zilla! with a lot of mods a 250r may run with one.
Old May 11, 2005 | 10:07 PM
500zuki's Avatar
The only thing that will hang with the Quadzilla is another Quadzilla. The banshee has no lowend and you are constantly shifting to stay in the powerband. The new sport quads are overpriced and will not keep up although they have better suspension. I purchased a 2005 YFZ450 and after a few months sold it and decided to keep my LT500 and just buy new shocks for it. I have never had any problems with my LT and ride with several friends who have YFZ's and 450R's and have no problem running with them.
Old May 11, 2005 | 10:21 PM
flynhi250r's Avatar
He didn't ask if a zilla would keep up he askes if any thing else would I stated a Banshee would be the only thing CLOSE. Have you never had any clutch or transmission problems because that was the weak point. You shouldn't have any problems running with, them you should be killing them.
Old May 12, 2005 | 10:16 AM
Duneaddict's Avatar
Don't kid yourself, a stock banshee isn't even close! This debate has raged on for many many years. The new yfz is closer than a banshee.
Transmission and clutches are weak? That's a new one. The clutch pack is comparable to what's used in the GM 3 speed automatic (Commonly known as the turbo 350).. I'd recommend some stiffer springs if your making big HP, but there's nothing wrong with the bottom end.
Old May 12, 2005 | 02:04 PM
CTATV's Avatar
only thing thats gonna hang with a zilla stock is that black widdow 600+ CC two stroke quad that isnt in production yet. gonna cost 10 Gs and have 100HP out the door
Old May 12, 2005 | 05:31 PM
yagerzzz's Avatar
Nothing's really comparable. If you could cross the power of a DS650 with the weight of a Banshee, you'd be close but still not quite there. A yfz will accelerate off the line close to a stock zilla (it may even have an edge in extremely low traction situations), a Banshee is right there with it when it's in its narrow power band, and a DS 650 has the grunt of a zilla at lower RPM's. Uncork the zilla and there's not much of anything that will touch it except crotch rocket powered quads.
As far as the 250R's and LT250R's, they won't hang with the zilla in drag races or top speed. Off the line it's close but the zilla still wins. Once they get up to speed, the difference is even more noticeable. My '87 LT250R (fastest year) is ported, piped, and jetted and is pretty fast for a 250, definitely faster than stock. My 100% stock '88 zilla (not even as fast as '87 zillas) will edge it everytime off the line and destroy it at higher speeds. My 250 in 6th gear is pulling pretty hard once I top it out in the low 70's. The zilla in 5th gear tops out closer to 80, and honestly it's playing at that speed. It feels like it could pull 2 more gears if it had them.
ReconBayou
Oct 16, 2019 02:24 AM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Irishman301
Sep 23, 2015 01:47 PM
Ashley S
Aug 6, 2015 12:56 PM
