86 Quadracer Problems
Old May 16, 2005 | 12:41 AM
Dugyoot82's Avatar
Default 86 Quadracer Problems
I just got the bike free and I am putting it together....I got it to kick and it idled low but it ran then the idle started to pick up and then I revved it....it didn't idle after so I pulled the spark plug wire out to kill the bike because I can't figure out how to hook up my kill switch...It ran for a few seconds and now it won't...I changed plugs and reconnected the wiring....please help!!
Old May 16, 2005 | 12:48 AM
theCATman's Avatar
Sounds like an air leak. Check carb boot,head for cracks, ALL GASKETS & SEALS, crank seals especially. Easiest way I've found is to get the engine running, & spray carb cleaner ( use very little ) around the carb,intake boot, head, magneto, etc.
Good luck.[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 16, 2005 | 04:41 AM
Dugyoot82's Avatar
got the bike running it was something stuck in my carb...I just can't figure out how to work my kill switch....unless it is faulty...
Old May 16, 2005 | 11:28 PM
sblt500r's Avatar
should be a black and yellow and a black and white that goes to the handle bar switch. the black and white is your ground.
can't be to many lt250r's in hawaii!!
Old May 17, 2005 | 05:47 AM
Dugyoot82's Avatar
there is a few...more banshee's then anything....I want mines to keep up with them...so I think I may bore mines about .60 over...and some other stuff. Oh the kill switch has a black wire and a white wire....do I hook up the black with yellow to the white wire and ground the black?
Old May 17, 2005 | 12:43 PM
sam250's Avatar
Keeping up with a banshee? That's not going to happen in a drag race, but in the twisty stuff you should be ok. It's going to take a lot more than a bore to make the 86 LT motor as fast as a well-tuned, piped Shee. Put a Zilla motor in that frame and it's a different story.
For the kill switch, the black/white wire goes to ground and the black/yellow goes to the switch.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
