fried wiring 2001 lt-f300f
I have a 2001 lt-f300f king quad a wire came loose and burnt some wires(black/white). I repaired it. blows the fuse. I found two coil wires burnt under the seat. I repaired these. still same problem. disconnect the black/white wire in speedometer case and all is ok it charges and does not blow the fuse. should I check the rectifier. [img]i/expressions/face-icon-small-confused.gif[/img]
