Pro Design Kill Switch on Z-250
Old May 31, 2005 | 01:14 AM
Pistonman's Avatar
Default Pro Design Kill Switch on Z-250
I installed a P.D. kill switch on my daughters '05 Z-250 today.
I hooked it short wire to ground, and long wire to the white/blue wire on the coil.
It works as it should at idle, but if you hold some throttle and pull the cord out it stays running till you let off the throttle.
I know if you fall off you won't be on throttle, but it just doesn't seem right.
Where should I connect it? Found nothing on a search. Thanks
Old Jun 2, 2005 | 01:33 AM
Pistonman's Avatar
I guess nobody knows.
fordfaithful21
Dec 7, 2015 05:52 PM
nick c
Sep 13, 2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
