Tune up time...
Old Jun 17, 2005 | 02:20 PM
SuzukiDoug's Avatar
Default Tune up time...
OK well its time to change the oil, oil filter, and spark plug. I am going to the dealer to pick everything up and I was just wondering if there are any little "tricks" I should know or anything I should pick up before I start this process? Thanks for any info!!
PS This is the first time I have changed oil on an ATV... any thoughts? I do know mechanics though [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 17, 2005 | 04:04 PM
ss97's Avatar
Lets Ride!
Very simple oil change on the z400.
Just make sure you remember there are two drain plugs. And I've heard people say they lost an o-ring on the oil tank drain plug but beyond that no big deal.
Old Jun 17, 2005 | 05:19 PM
SuzukiDoug's Avatar
OK got that all done, that was easy, a little messy though. I am also wondering. I looked at the oil and it looked like it has never been changed. Damn guess thats what I get for buying used. Well I think I am just going to watch it and change it again after its first day of riding and see if I can see anything wierd or what not.
Now I am wondering. I was looking at the intake and it is just plain horrible. I mean I noticed it before but well I guess it isn't too bad but I am thinking about just replacing it rather then cleaning it. Should I just go with a K&N filter or stock? Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 17, 2005 | 11:17 PM
MeYHymN's Avatar
Uh oh, I think someone just opened ye ole proverbial can of worms. K&N vs. stock. Most of this is going to be opinion though I believe it to be fact, come all ye naysayers have at thee! K&N flows more air than stock, but unless your rejetting the carb or changing the pipe you're only heading for a lean condition. You could probably adjust the needles to compensate but then you're just defeating the purpose of the high-flowing filter. Now, I personally, probably wouldn't use a K&N considering the conditions these quads go through with excessive sand, dust, and other debris flying in the air. Just my $0.02 and take it for what it's worth. Stick w/ stock till you upgrade elsewhere in the fuel/exhaust system.
Old Jun 18, 2005 | 08:59 AM
ss97's Avatar
Lets Ride!
Just a K&N alone should not cause a lean condition, I've put K&Ns in many things and no re-jetting was needed.
However, as far as performance goes stock VS K&N is another debate. I've seen dyno test with both and the only real gain is at the very low-end of the scale. The K&N tends to allow quicker air response at the very first second, the moment when higher suction starts. Beyond that there can also be slight gain in suction at the higher RPMs too. But through the curve the change is only slightly measurable. A clean stock filter in good condition is fine.
The only siginificant upgrade with a K&N is the fact you don't have to replace it, ever. You only have to buy one once. However you do have to buy the stuff to clean and oil it so it may be a wash.
Old Jun 18, 2005 | 09:58 AM
GLDIVER's Avatar
Do yourself a HUGE favor, get rid of the stock air filter! Not for performance but for engine longevity. They don't seal well at the mount. I highly reccomend the Noss Machine adapter and UNI filter. I think the UNI filter is better for dusty conditions than the K&N.
Check it out here.
With a small amount of customizing this adapter and filter fit my Eiger also.
Old Jun 18, 2005 | 10:53 AM
rolsmojave3's Avatar
yup get the adapter....you won't be worrying about crap in your intake....
Johnny Mac
Aug 15, 2019 03:13 PM
CosmoM
Sep 21, 2015 04:57 PM
Jason Poulin
Sep 20, 2015 02:49 AM
Alex G.
Sep 16, 2015 12:13 PM
Elkaholic
Sep 6, 2015 02:44 PM
