how do you adjust cam chain tensioner? (Z-400)
Old Jul 13, 2005 | 03:32 PM
MURDR's Avatar
Default how do you adjust cam tensioner? (Z-400)
Old Jul 13, 2005 | 04:24 PM
ss97's Avatar
Lets Ride!
Default how do you adjust cam chain tensioner? (Z-400)
I'm pretty sure it's an automatic chain tensioner just like in a car engine, so I don't think you can adjust it. I could be wrong and if I am I'm sure someone will tell you here.
Old Jul 13, 2005 | 04:35 PM
MURDR's Avatar
Yeah i thin k you can , or to see how many clicks you have left.???
Old Jul 13, 2005 | 05:17 PM
fullthrottlez400's Avatar
Get a manual lol....price is alittle hefty for a book but its worth it
Old Jul 14, 2005 | 11:02 AM
witti's Avatar
The stock tensioner adjusts automaticly. You can check how much adjustment is left. The tensioner is on the rr side of the cyll. Pull the center bolt out of the adjuster (12mm head). Then remove the spring that it holds in. Next remove the 2 allen head bolts on the tensioner and pull the tensioner out. After its removed you can pull on the center shaft and count how many clicks are left before it is all the way out. Before reinstalling you need to push the center shaft all the way in. Then assemble in the opposite order.
I just replaced my timing chain 2 days ago. I only had 1 click left on my adjuster. Most people that I hear of changing them do it with 3 or less clicks left on the adjuster.
I used a HD Did cam chain, its commonly used on another website. I got it from advantagecyclelc.com for around $60.
Old Jul 14, 2005 | 11:05 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
That is exactly how I check it on my KTM. I always wondered if others were the same.
Firefighter400
Oct 8, 2022 06:38 PM
bvolks
Dec 26, 2015 08:43 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
