Loading Quad into Pickup
Old Jul 29, 2005 | 04:58 PM
Scooter86's Avatar
Knows Old ATV Questions!
Default Loading Quad into Pickup
I actually use both. While a bigger trailer would be ideal, I use the 4x8 trailer I do have and drive the quad onto the trailer and then up the ramps to the truck bed. (my ramps are also a bit short to get into the truckbed by themselves.) I've seen quite a few others do this as well. It aint pretty, but at least I can bring two quads at once! I'll second the making good use of safety straps and having a touch of momentum. Just remember, you don't want to use the cab of your truck to stop with though.
Old Jul 30, 2005 | 12:18 AM
DavidLT250S's Avatar
buy or make ramps that have rough expanded metal on the top of them the tires grab in really good so you don't have to worry about spinning or just get a trailer
Old Jul 30, 2005 | 03:31 PM
sam250's Avatar
Originally posted by: Dante7
Hey you don't need ramps just get up in the bed of the truck grabahold of the front rack and set the front tires on the tail gate then get out lift and push the back the rest of the way into the truck. Then to unload just grab the back pull the backwheels off and set the skid plate down on the edge of the gate catch you breath then lift and pull the front end off and let it fall to the ground.
Not everybody's quad weighs 296 Lbs dry.
Old Jul 31, 2005 | 12:41 AM
arnard's Avatar
I let my winch do the work. I ran a chain across my front two tie downs in my bed. I just leave it there all the time. Snap the hook on the chain and put the quad in neutral and it will pull it right up. Works well for me when I don't use the trailer.
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
