Adjustments
Old Aug 17, 2005 | 07:21 PM
Tremhead's Avatar
Default Adjustments
I have a 2004 Suzuki Z-250, and when i shift it makes a clunk noise. I did try turning the idle down on it but that did not work. I was wondering if there is another adjustment that i can do to it or if i need a new part. Thx
Old Aug 17, 2005 | 11:44 PM
Torbinx's Avatar
Default Adjustments
Its most likely the result of improper shifting. Be sure to shift the atv with the throttle off. If you had shifted with the gas on constantly then your automatic clutch could be worn out. Just a possibility but make sure.
Old Aug 17, 2005 | 11:49 PM
Dante7's Avatar
Default Adjustments
Does it do it just when you shift into first or all of the gears
Old Aug 18, 2005 | 09:22 AM
Tremhead's Avatar
Default Adjustments
It clunks harder in 1st and 2nd, but it does clunk in all gears
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
