2-Stroke vs 4-Stroke owners
#41
Originally posted by: Slinger Hauling elk out on a motorbike sounds goofy, anyway. Try a pack animal. Maybe an *** so there'd be two of ya.
#42
Also the way a quad puts its power to the ground can determine what type of pulling it will do. For example if you had a ute with a manual clutch and chain drive ot probally wouldt pull as well as one witha semi-/fully auto clutch and shaft drive.
#43
Originally posted by: midnite
Not all 2- strokes have to be reved to the moon to make power. Sure a banshee doesn't have much low end power, but it wasn't made to produce low end power. You can make a 2-stroke motor produce as much low end power as a 4-stroke. On a 2-stroke the pipe determines where in the rpm range the power band will hit. If a 2-stroke has a pipe that wont let it rev beyond say 7000 rpm, and has a smaller carb, it will produce ALOT of low end torque and a smooth powerband {not much top end power}. If a 2-stroke has a pipe that lets the motor rev to 12000 rpm, and has a large carb, it will make ALOT of top end power {not much low end power} and have a violent hit in the powerband. It all comes down to where the motor was designed to make power. And whats with this "burning up clutches" thing. It either is engaged, or disengaged, just like a 4-stroke.
Originally posted by: Niskibum
It's not just a matter of how much torque, it's where the torque is in your power band. 4 strokes typically have a much lower power band than 2 strokes, so pulling a heavy load up a steep incline is much easier with a 4 stroke since your power band is much closer to your shift points. A 2 strokes power is a function of rpm, so you have to get your rpms up before you hit the power band, which doesn't work well for overcoming the inertia of a heavy load, especially on a hill.
As you can see from what I wrote, I said typically 4 strokes have a lower power band, but I think that if you were to spend as much effort on a 4 stroke (which manufacturers are making even better every year) as you are talking about to change the power band of the 2 you would see just as dramatic an improvement without having to deal with the other issues like oil mixing, shorter engine life, noise, poor fuel economy, fouling plugs, pollution, etc. What I meant by burning up clutches is just that when you are climbing steep terrain with a heavy load you will have to slip your clutch a lot more with a higher power band than you would with a lower one, which is not only hard on the clutch, but a pain in the rear to boot. It's true that quads with cvt's behave differently, but that's part of the reason I bought the Vinson manual.
You have to remember that my point of view is one of someone that uses my bikes and quads not only to have fun, but to do some serious work. Unless you have done it, you may not understand everything involved with getting an animal like an elk off a mountain, but you can be sure that the low end grunt of a 4 stroke engine can be very usefull in doing it.
As for other posts here, I'm not even going to waste my time anymore replying to people that resort to name calling and insults to try to prove their point. I think those posts say far more about them than they do me.
#45
Niskibum, I think your posting, what 25 in all, has been a total waste of time anyway.
You were wrong about torque/2 strokes so don't go away mad, just go away. In case you haven't noticed this is an ATV forum.
#46
#47
Lets put it this way a 400 polaris 2-stroke ute has more low end torque than a yfz 450. Just like a honda foreman has more low end torque than a banshee. Race bikes don't give a **** about low end torque, be it 2 or 4 stroke. Utes don't give a **** about about top end power, be it 2 or 4 stroke. Again it all comes back to what the motor was designed for, regardless if it's 2 or 4 stroke.
#48
Which 400 Polaris are you talking about? Must be from a different year, since every Polaris they make over 250 cc's is a 4 stroke according to their site. Same thing with Suzuki, and every quad other than the blaster and the banshee from Yamaha. I couldn't even find a Honda 2 stroke atv, as well as Bomb. I might have missed one somewhere, but it seems that the 2 stroke atv is on it's way out. I find it hard to believe that is only due to emmisions and fuel consumption. Probably more like durability, since an engine that doesn't come back for warranty repairs is better for the manufacturer, even thought they are heavier and more complicated to produce.
I'm not saying that 2 strokes don't have their place, especially in off road motorcycle racing, but I don't think they can compete with a 4 stroke in a utility application, (my point all along) either on a bike or a quad. That's why you never see a Rokon with a 2 stroke.
I'm not going anywhere enFORCER, I'm just only responding to the adults on this thread.
#49
#50
