Will fog lights for a 12-volt system work on my LT250r?
Old Sep 1, 2005 | 03:38 AM
teoamaru's Avatar
Default Will fog lights for a 12-volt system work on my LT250r?
Any help would be greatly appreciated. The lights are 55 watt halogens. Thanks all!!
Old Sep 1, 2005 | 03:27 PM
SuperSuzuki4's Avatar
They will work but not well. The lights run off the motor and it may overload your system. Even the stock light goes dim when at idle.
Old Sep 1, 2005 | 08:50 PM
ChewyR's Avatar
I had a TRX250R once upon a time that somebody had intalled some round off-road 4x4 lights on and they worked okay. The issue you run into is the stock stator isn't wound to produce enough power to supply two 55 watt bulbs, therefore they may be dimmer than you would excpect. But if wanted you could have the stator re wound or buy a high output stator to supply the needed power.
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
VascoConroy
Jun 12, 2015 10:30 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
