problem with 04 eiger
Old Sep 6, 2005 | 10:24 PM
erb's Avatar
erb
Default problem with 04 eiger
I have a 2004 eiger automatic that is making an intermintant clunking noise when it is in 2WD . It sounds like it is coming from the front end. It almost sounds like its wanting to engage into 4WD. I was wondering if it could be a linkage problem that might be able to be adjusted? Any guesses or suggestions?
Old Sep 6, 2005 | 10:38 PM
Gipper98's Avatar
does your machine have a manual hand lever on the left side of the machine that is used to select 2wd/4wd?
Old Sep 6, 2005 | 10:44 PM
erb's Avatar
erb
It has a lever on the right side on the handle bars.
Old Sep 6, 2005 | 10:47 PM
Gipper98's Avatar
i think the eiger uses a cable attached to that lever to engage the 4wd. if thats the case, there should be a cable adjustment somewhere....
Old Sep 6, 2005 | 10:51 PM
rolsmojave3's Avatar
does it do it while turning....does it jerk the bars...it could be a CV joint ...i had one go on mine
Old Sep 6, 2005 | 11:06 PM
erb's Avatar
erb
It doesn't seem picky when it does it. It does it when I turn or go straight. it doesn't jerk the bars and I can't really feel it when it happens. I haven't left it in 2WD long to really pinpoint the source as I am afraid of doing damage mechanically.
Old Sep 6, 2005 | 11:13 PM
Gipper98's Avatar
i'd block the whole machine off the ground and test it, try to figure out exactly where the noise is coming from. as said earlier, it could be a cv joint or it could be inside the differential.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
baysport
Jul 23, 2015 11:37 AM
hondarider1234
Jul 21, 2015 11:53 PM
