z400 timing chain
Old Sep 23, 2005 | 06:19 PM
garrett5462's Avatar
Default z400 timing chain
my z400 is ticking pretty good form the right side of the engine and i read somewhere that it could be the timing chain tensioner could be maxed out, so how do you check this? thanks.
Old Sep 23, 2005 | 07:34 PM
welby's Avatar
Pick up a manual, it will be your best friend ever.
The way to test it is by 1st removing the center bolt in the tensioner. There's a spring on the back side of it, remove the whole assembley. Once the center bolt is removed then remove the outer two bolts and pull the housing off the head. Once you have the tensioner housing removed then simply pull on the shaft w/ the teeth very slowly and count the number of clicks left before it's extended all the way. Once there are only about 2 or 3 clicks left before full extension then it's time to start thinking about investing in a new cam chain, preferably a HD chain so you won't have to do it again. There are 12 clicks on the tensioner. When I reinstalled mine with my heavy duty chain it went in 4 clicks, leaving me with 8 clicks off adjustment.
Old Sep 23, 2005 | 10:13 PM
ok, i guess i need a sevice manual,
Old Sep 25, 2005 | 11:25 AM
Appock's Avatar
Does anyone know where to get a service manual for a '03 z400? Not even sure where to start looking!
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
