Help on warn winch !
Old Sep 24, 2005 | 12:25 AM
TxKingQuad's Avatar
Default Help on warn winch !
I'm trying to install a new warn 2.5 winch. I got the mount and winch mounted without any problems.I mounted the
contactor under the seat, ran the blue and yellow wire from the winch to the contactor, I mounted the rocker switch
on the handlebar and found the 3 wires under the dash and ran the green wire to the green wire, ran the black wire
to the black wire and ran the red wire to the orange wire.........I think i'm good so far. Next I connected the black and
red wire to the contactor then to the battery all good...........My problem is on the contactor block there are 2 wires with
bullet connections on them 1 green 1 black where do they go ?
This is on a 2005 Kingquad
Old Sep 24, 2005 | 01:10 AM
muddude's Avatar
I believe the green and the black wire go to the contacter and the red wire gets connected to the orange wire on the quad!
Old Sep 24, 2005 | 02:55 PM
melssavage's Avatar
On mine the rocker switch from the handle bar pluged into the contactor. And the single red wire spliced into the ignition switch wire which was in the front of the machine right above the radiator. It has a plug on it already. That was all there was to it.
Old Sep 24, 2005 | 11:02 PM
CBF2's Avatar
What they said X3.
Old Sep 29, 2005 | 11:34 PM
GSPKurt's Avatar
What he said. Those wires don't hook into the wires by the ignition switch.
Old Sep 29, 2005 | 11:43 PM
TxKingQuad's Avatar
I figured it out .....the dealer gave me the wrong wiring and rocker switch.I got the short wires when i needed the long ones.I'll be working on it tomorrow and let yall know how it goes.
Thanks
Old Sep 30, 2005 | 03:25 PM
GSPKurt's Avatar
That should make life easier for you!
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
