z400 performance questions
Old Oct 7, 2005 | 09:56 AM
ep's Avatar
ep
Default z400 performance questions
I looked at the K@N lid---you're right---EXPENSIVE...
What I'm thinking about doing is taking your advice and drilling a few holes and cannibalizing an old filter and rigging it to the underneath side of the lid. When you did this what did you find was the best way to secure the foam? Small bolts and washers? Super glue? Duct tape???
Old Oct 7, 2005 | 03:50 PM
jaxxdog's Avatar
The K&N lid filter is ex$pensive, I put an outer wrap on the K&N filter and I have not had any issues except, I clean the outer wrap after each ride. The idea of the pre-filter wrap on the out-side of the lid is a good idea, I will have to try it. Thanks for the idea and good luck.
Old Oct 8, 2005 | 01:15 AM
CBF2's Avatar
I put the piece of flat oiled foam against the lid then put a sturdy plastic screen (from a hobby shop, like they sew yarn into or something) under it. Then just bolted through everything with some big washers on the screen side.
That stopped most of the dirt from even entering the air box. I rarley had to clean the ATV filter, just took off the lid, hosed it off under pressure, and reoiled the foam without removing the screen.
Valder
Nov 28, 2020 07:38 AM
NewGuy2481
Oct 6, 2015 05:54 AM
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
1ArmBandit
Sep 8, 2015 08:59 PM
