King Quad Top Speed
Old Oct 27, 2005 | 11:42 PM
05KFXKingQuad's Avatar
Default King Quad Top Speed
with 27"ITP XTR on type 7 14" rims. My KQ only has 9 miles on it now and I could only get up tp 58mph. They say they will do 72mph, but 58 is a long ways from there
Old Oct 28, 2005 | 12:10 AM
CBF2's Avatar
Put the stock tires/rims back on and try again. Sure the larger diameter should increase the speed but if the King can't turn them you will suffer.
We'll forgo the discussion of whether or not you should be running WFO at 9 miles or not and the importance of top speed.
Old Oct 28, 2005 | 12:48 AM
alltoos's Avatar
the bigger tires give the speedo a wrong reading.
Old Oct 28, 2005 | 01:02 AM
yellowrider250ex's Avatar
your going alot faster than the speedo says
Old Oct 28, 2005 | 01:28 AM
LOANSHARK's Avatar
Lets not pass on that little jewel of a discussion. There are some very experienced people who will tell you the best way to break in an engine is to let the thing warm up, then ride it like you stole it.
The owners manual version of break in was originally written when engines were made by hand, and hasn't changed with the times. If you don't get on it some in the first 20 miles you run the risk of your rings never seating properly and an early ring job.
The cross hatching today is much finer than it used to be and wears smooth very fast, if you don't put some pressure on those rings early your engine will not last as long.
Old Oct 28, 2005 | 08:03 AM
BobVT's Avatar
My gps registers far less than the speedo. Speedo at 65 and gps at 58 with stock tires. I really don't care because the majority of my riding 99.9% is on the trail. Top speed is not a good point to measure a utility quad.
Larger tires will change your speedo and slow down the low end. I imagine it will amplify the low end lag.
Old Oct 28, 2005 | 01:08 PM
KingFan's Avatar
Larger tires and rims will throw off any speedometer (cars, trucks, ATV etc.). So your reading isn't going to be accurate. I have 26" Mud Lites on mine. My top speed shows 62. A GPS would reveal what it really is ---but--- Whatever my real speed is (when it shows 62), is as fast as I want to go!! --- It felt very fast!!
Old Oct 29, 2005 | 12:53 AM
Glenlivet's Avatar
[quote]
Originally posted by: LOANSHARK
Originally posted by: CBF2 There are some very experienced people who will tell you the best way to break in an engine is to let the thing warm up, then ride it like you stole it. ...The cross hatching today is much finer than it used to be and wears smooth very fast, if you don't put some pressure on those rings early your engine will not last as long...
I have read that stuff and it makes perfect sense.... BUT we are not talking about an iron cylinder liner here in the 700 King Quad but an aluminum cylinder with a plasma spray coating. We have just changed a major component in the break-in philosophy. How does this spray coating cylinder respond to the high combustion pressure ring seating theory? Who has tried it on a King Quad?
There are already reports of accellerated cylinder interface wear in 700 King Quads believed to be a result of a poor air cleaner passing dust... is the spray cylinder liner maybe more delicate than the old iron liners that have worked well for years? Too delicate to tolerate the hard break-in?
Old Oct 30, 2005 | 01:11 AM
THE700KING's Avatar
hi guys ive got 1500 miles on my king now 1350 of them w/14" 27"itp's my gps shows 65, speedo shows 61, i go with the gps...but the odo on the king and the odo on the gps show the same miles traveled so it's just the speed that is off.. this buy far is the best quad i have ever owned...thanks
Reactant
Mar 30, 2022 02:08 AM
Scottma518
Jul 16, 2015 09:19 PM
ranvette
Jul 12, 2015 06:34 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
