Wiesco or Pro X
Old Nov 7, 2005 | 01:12 AM
maddog56's Avatar
Default Wiesco or Pro X
Pro-x pistons are designed to be oem replacements, so similar design and materials. That would explain the differences in clearances the last poster noted.
Old Nov 7, 2005 | 02:42 AM
boat's Avatar
They are starting to use high silicon aluminum that does noy expand as much so you can run it on the tight side
Old Nov 7, 2005 | 03:03 AM
86250rrider's Avatar
the auto pistons called hypereutectic are cast with higher silicon content than regular cast pistons. my street-strip ride uses trw forged pistons only because i was thinking about spraying it. two years later i picked up another 100 hp with better cam,intake ,carb selections and lots of tuning. 420 hp isnt bad for a 355 sbc. i cant spray now using the cast crank(breakage). those pro-x cast pistons are also quieter on startup. you can hear the difference . cold seizures are more of a problem with forged pistons also. its all in what you like. if people would learn how to jet properly ,they all would last longer! my r is only .030 on original jug. that dumonde is some pretty good stuff!! LONG LIVE THE 2 SMOKERS !!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 7, 2005 | 03:33 AM
boat's Avatar
They are using silicon in forged pistons as well
polarsport500
Apr 29, 2004 07:52 AM
missinglink
Mar 12, 2004 02:16 PM
Rider1169
Oct 3, 2003 06:01 PM
Kickerz
May 30, 2003 11:42 PM
ryenol
Apr 30, 2003 12:53 AM
