91'lt250r rear axle nut??
Old Dec 6, 2005 | 12:02 PM
jmane's Avatar
Default 91'lt250r rear axle nut??
Hey, I just bought new axle bearnings for my lt, and I cant seem to get the inner axle nut off on the sprocket side, and in my book it says if u cant get it off then chisle it off, and I dont really want to do that, just wondering if anyone has had the same problem,and what should i do to break it loose, heat, special oils,ect, any info would be very thankfull.
Old Dec 6, 2005 | 10:07 PM
quadracer325's Avatar
Use a big pipe wrench, cheater bar, and have a buddy hold the quad down, it'll come off. Soaking with penetrating oil over a couple days might help. Heating it probably wouldn't hurt either since your putting new seals in with your bearings. I've always used a pipe wrench though.
Old Dec 7, 2005 | 08:01 AM
800screws's Avatar
i agree, pipe wrench and torch it. u probably don't want to spend money, but magic racing sells billet locking nuts for the lt250r pretty cheap. u need 2 though.
Old Dec 7, 2005 | 12:53 PM
sam250's Avatar
I've always heard that you can't use heat because you'll weaken the heat treatment of the axle. If you use anti-sieze and then cover the nut with electical tape when you reassemble it, you won't have this problem again.
Old Dec 8, 2005 | 09:18 AM
jmane's Avatar
Well bad news, I sprayed it with pb blaster and let it sit for a couple days, then tried a pipe wrench, but i had nobody to hold it down for me so i supidly put a big wrench between the rear sprocket and the swing arm and broke it right on top where i had it welded last year, and the nut still isnt off so the only thing i can think to do now is buy a whole new set up,swingarm,axle,and bearning carrier, any one know where i could get them,brand new it will be 1700 for everything, wanted to get used ones, I live on the border of maine and new hampshire at the southern most part of maine,any info would be great, Thanks
Old Dec 8, 2005 | 07:10 PM
quadbart's Avatar
EBAY
Old Dec 8, 2005 | 08:20 PM
sonofcesare's Avatar
ive got an 88 im gonna part out. good axle and swingarm. let me know
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
