z250s
Old Jan 4, 2006 | 12:16 AM
  #91
suzukirider55832's Avatar
Default z250s
what would you make thpse helguards out of? something like t-6 aluminum or something
Old Jan 4, 2006 | 12:24 PM
  #92
dunbarr's Avatar
Default z250s
Thats what I would make them out of.
Old Jan 4, 2006 | 01:59 PM
  #93
ElectricShift's Avatar
Default z250s
I called DG performance right before I got rid of my z250 and asked them to make heel guards for the Z250's, he said he would if he got enough requests for them.
Old Jan 4, 2006 | 02:37 PM
  #94
SuzukiDoug's Avatar
Default z250s
I called that shop and they answer the phone from 4-7PM EST. I will be calling them back at that time to see if they make a kit for the Z250. I need something for this thing. Thanks for the ketting advice I will look into getting a 136 cause I am going to take the airbox lid off. I will let you know what she dyno's I should be doing it this weekend. Thanks!!
Here is the dyno sheet from my other Z
Old Jan 4, 2006 | 02:46 PM
  #95
Default z250s
Here That's my old z250 I figure i'd post it since this is the z250 thread.
This is our other one, we no longer own it either.
another pic
Old Jan 4, 2006 | 02:50 PM
  #96
SuzukiDoug's Avatar
Default z250s
So pretty much I am stuck with a pipe for an upgrade.. I think I might call a local shop to get a little porting done also... hmm that is a good idea! DAB racing here I come again!
Old Jan 4, 2006 | 04:27 PM
  #97
Default z250s
i say we try to get every single person on here to call companys like dg for heelguards, wiseco for pistons/big bore kits, and hot cams for cams...maybe if they get enough request for a high enough dmeand to make the product they will make it and we can get the best out of our zs...i say we contact dg for body work maier for plastics, wiseco for piston and big bores and hot cams for cams...any other suggestions? and i will also contact members of other forums as well...we need to get some more shizzle for or quads...also i will get some phone numbers...brb
Old Jan 4, 2006 | 04:40 PM
  #98
Default z250s
ok hot cams phone number-515-402-8005
http://www.hotcamsinc.com/contactus.asp you can get to thier email address there if you dont want to call them
wiseco phone number 1-800-321-1364
dg phone number-1-866-653-1647
okay post some more numbers if you got any more
Old Jan 4, 2006 | 06:27 PM
  #99
Default z250s
I don't see why you guys want motor work so bad I never really wanted that out of my z250.. even if you did beef your motor up with big bores you're still limited by shaft drive so you can't regear, auto clutch, ect.
They're entry level quads, basically a utility with sport plastics don't try to make it something it's not.
But I do agree that there is a lack of aftermarket for them, the stock heal guards are gross and aftermarket plastic would be nice.
Old Jan 4, 2006 | 06:34 PM
  #100
dunbarr's Avatar
Default z250s
Well said, I was thinking along the same lines.
