z250s
Old Mar 17, 2006 | 10:33 AM
  #561
suzukirider55832's Avatar
Default z250s
Originally posted by: s9195
91CavGT - did you say you were looking for a stock Z400 carb??? I have an extra one. The only problem with it is it looks like the choke appears to be stuck open. I got this in a box of items I bought on eBay. Other then that all else looks good. Didn't need it but came in a package deal. Let me know....
it's rather easy to fix a choke...did you ever take the carb apart?
Old Mar 17, 2006 | 12:55 PM
  #562
s9195's Avatar
Default z250s
Nope.. never took it appart. Only pulled on the throttle cable to make sure it still opened the carb. The choke plunger is stuck in. Who ever parted the original quad simply cut the choke cabel and left the plunger in it.
I may tinker with it sometime.. but for now I'm to busy rebuilding the rest of the quad (check out my page for picts). I only mentioned it because in past threads someone said they needed a stock 400 carb.
Old Mar 17, 2006 | 02:59 PM
  #563
91CavGT's Avatar
Default z250s
Oh yeah, I am still looking for a stock Z400 carb. When I get the turbo on my Ozark, I am going to need the larger carb to flow the air and the fuel that the motor will require.
Send me a PM or email me at Cav_GT@yahoo.com and let me know what you want for it.
Old Mar 19, 2006 | 08:09 PM
  #564
Default z250s
if you end up getting it, tell us how it's working for ya
Old Mar 20, 2006 | 01:36 PM
  #565
91CavGT's Avatar
Default z250s
I know you guys probably don't care, but over the weekend I snorkeled my Ozark as well as I installed a set of HUGE aftermarket headlights. I kept the stock headlights in place, but I wired these aftermarket ones up to the high beams. So with low beams on, the stock lights light up, then when you switch to high beams, the aftermarket ones light up. I had to replace the bulbs in these though. They had 130 watt bulbs in them!! That would have killed the electrical system! I put in 55 watt bulbs instead.
Tuning the quad now with the snorkel is proving to be a PITA!! I keep fouling out plugs.
Old Mar 20, 2006 | 02:01 PM
  #566
s9195's Avatar
Default z250s
91Cav - I've sent you an email.. sorry but I was out riding this weekend and got back late last night.
Old Mar 20, 2006 | 05:30 PM
  #567
Default z250s
post some pics 91cavgt!
Old Mar 20, 2006 | 08:20 PM
  #568
z25012566's Avatar
Default z250s
hey guys i finaly did it i miss juged a jump and went right over the handle bars and got this awsome bruse [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 20, 2006 | 08:24 PM
  #569
dunbarr's Avatar
Default z250s
Now theres a good start . LOL!
Old Mar 20, 2006 | 11:11 PM
  #570
LTZGUY's Avatar
Default z250s
on your snorkel setup if you are fouling plugs that tell me your getting less air. you can do 1 of two things, try going down on jet size, or increasing the size of your snorkel pipe. if it was me, id increase pipe size if possible. more air=more power. my clutches and manual conversion came in today.....gonna try to work on it this week. the only complaint i have so far is the lever on the clutch is way shorter than the brake lever.....hmm, time for a upgraded brake lever. i'll let you know how it turns out.
