230 oil leak
Old Jan 22, 2006 | 08:40 PM
quadsport230rider's Avatar
Default 230 oil leak
i recently took apart my quadsport 230 and it now has an oil leak. is there any thing i can do to stop it without taking it all back apart? at an auto parts store i noticed this stuff in a bottle that u pour in with the oil and it says it stops oil leaks . does it really because it is kinda pricy. the leak only comes out of one spot but it rapidly comes out pretty fast
Old Jan 22, 2006 | 08:52 PM
smb05's Avatar
quadsport230rider,
I know it's a pain in the a$$ to take it all apart to make the repair. But you should fix it correctly, so you don't have to worry if your temporary repair is going to last. Let say your temporary repair gives out on you 35 miles away from camp what then?
Just my 2 cents.
SB.
Old Jan 23, 2006 | 10:46 AM
AtomicPunk's Avatar
The automotive stop leak stuff probably won't work and it could damage your clutches..most of that stop leak stuff is made with the same compounds as brake fluid which will swell the seals to try and stop a leak in cars..but I believe it will damage the clutch on quads..
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
