TOP SPEED 400Z!!!!!!
Old Feb 13, 2006 | 06:17 AM
BlackKawi400's Avatar
Default TOP SPEED 400Z!!!!!!
Wiseco Big Bore = 440cc
Old Feb 13, 2006 | 04:53 PM
suzukirider55832's Avatar
Originally posted by: marlboro
how do u make it a 440, big boge kit or somtin, prolly sounds like a stupid wuestion, but jsut wonderin?
to bore an engine out, you first must know the sole purpose, to boring out an engine. as an engine is run, after the years, the cylinder sleeve/cylinder that the piston is in, gets kind of ovaled out, therefore, you lose compression. to bore an engine out, you round out the cylinder/cylinder sleeve, making it bigger at the same time...this is measured in millimeters...that's why when you look at high compression pistons, it says standard-.?? over...to bore out an engine, you purchase a big bore kit, tell the shop how many millimeters/cubic centimeters the atv will be bored out to...then they use a machine to round out the cylinder sleeve/cylinder, and then install the bigger piston and sleeve...this was not a very good explanation, but hopefully you will get the point...
Old Feb 14, 2006 | 12:47 AM
marlboro's Avatar
thanks man, i knew how to do it because i have a 2-stroke racing bike, i jsut wasnt for sure with the atv, but thanks for taking the time to tell me...keep em posted!!!!
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
