radiator fluid question
Use distilled water 50/50 or even better 60/40 (antifreeze/water) that protects to lower and higher temps...if you have the plastic reservoir tank fill the rad full and then the tank to the top -full- mark, thats about 2/3 way up....marked on the right side if I recall, at least on the 05 KQ it is.
Distilled water is cheap, use it, not tap or well water they have too many disolved minerals.
Technical and How-To Articles
Aug 21, 2015 09:31 AM
