Front Wheel Bearing
Old Feb 27, 2006 | 02:49 PM
shortcut5025's Avatar
Default Front Wheel Bearing
Front wheel bearing busted on my 04 z400 took the wheel off the hub then took the nut on the axle off 3 pieces fell out .There is what appears to be a spacer at the back of the hub or is that part of the bearing.The caliper bolts are stripped from trying to break them loose.So my question is is that a spacer and if it is can i just put a new bearing in or do I need to take the whole assembly off and get the caliper bolts out?Anyone have a diagram or a link to show a blow-up view of the front assembly?
Old Feb 27, 2006 | 08:53 PM
slomoe's Avatar
There should be a washer but you will need to take the hub off to replace the bearings i believe there are 2 in the front hub if 1 faild the other is sure to follow.
Old Feb 28, 2006 | 12:12 AM
mucky's Avatar
I hope this link works.
wheel hub
you will have to click on what type of quad and then front wheel
Old Feb 28, 2006 | 09:33 AM
BlackKawi400's Avatar
Okay....
It goes like this:
Rear Spacer-->Rear Seal-->Rear Bearing-->Bearing Spacer-->Front Bearing-->Front Seal-->Front Spacer-->Washer-->Castle Nut-->Cotter Pin
Front Hub Assembly
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
