sprocket mounting bolts
Old Mar 5, 2006 | 09:22 AM
mconner's Avatar
Default sprocket mounting bolts
what size are the bolts that mount the rear sprocket ? One of mine fell out and suzuki dealer wants $3.11 for 1 bolt and $2.54 for 1 washer .could't I just get a bolt and washer from a hardware store (next time i'll be using super locktite not medium)
Old Mar 5, 2006 | 01:13 PM
mucky's Avatar
just remove one and take it with you so you get the right one. and they are metric
Old Mar 7, 2006 | 10:37 AM
mconner's Avatar
I took 1 of the bolts to the hardware store and It threaded on a 10mm metric nut fine but won't fit in the hub. I can't find a 9mm bolt anywhere and 8mm is too small .I found a suzuki dealer that will get bolt and washer for $3.80 I know it's stupid - just sounds like a rip off for a dam bolt and washer.
Old Mar 7, 2006 | 09:32 PM
mucky's Avatar
yep. sometimes it crazy when the only place that has what you want is the dealer and then they charge you a arm and a leg and sometimes your first born for the part and you know it didn't cost that much to make it
Old Mar 7, 2006 | 09:58 PM
kawiking's Avatar
@#ck-n dealers!!!!!
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
Canamaniac!
Sep 15, 2015 06:19 PM
