do i need a new transmission??
Old Mar 7, 2006 | 08:08 PM
quadsport230rider's Avatar
Default do i need a new transmission??
my 87 quadsport 230 at high speeds winds out but doesnt go as fast as it should be. its like pulling in the clutch slightly and half disengages the motor but its only at high speeds just before u shift into a higher gear. do i need a new transmissio or just a clutch?
Old Mar 7, 2006 | 08:45 PM
Scooter86's Avatar
Knows Old ATV Questions!
What you are describing sounds like you just need a new clutch. How old is the clutch in it now? Do you slip the clutch a lot? If the tranny is shifting in and out of all gears fine, and doesn't pop out of gear on it's own, then I doubt you have any tranny problems.
Old Mar 7, 2006 | 09:15 PM
i think its the stock clutch but idk because i only had it for about two months. when i downshift in to first it makes a load clicking noise. its getting worse.
Old Mar 7, 2006 | 10:05 PM
Scooter86's Avatar
A loud clicking noise? Is your chain tight? Other than that I have no clue, but a lot of people here will have more knowledge on that. I'm sure someone will post shortly.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
